Originally Posted By: Gebo
Originally Posted By: dschultz
Almost all the pleated 1 inch filters have the problem of quickly restricting airflow. The higher the rating (MERV, etc.) the faster the filter will load up.
The washable filters can also be too restrictive. Although systems with ECM motors can compensate for restriction there is a limit and long term restrictions can cause coil icing when cooling, heat exchanger cracks on gas furnaces, and high pressure problems on heat pumps.
If you want to have high efficiency media filters I recommend you go as thick as possible and then select a high MERV rating.
I had a Carrier electronic air cleaner that finally failed, it was never as good as promised, I removed the cells and measured the space for a media filter.
I found a company the makes custom filters send me an 18 x 24 x 6 MERV 11 filter, $24 each minimum order of 4.
They last me about a year, fan running almost continuously, and no dust accumulating on blower.
I just found out what you did. My Lennox Electronic Filter is dead. It is a 16X25x5 on the inside. I'm gonna do just what you did and stick a Lennox filter in the empty slot. Wonderful! Thanks!
I also purchased some foam pipe wrap and placed a flat layer around the inside edge of my filter housing to provide an additional gasket. Added a layer on the air cleaner door too. I think the foam strip rolls are at Home Depot. I forgot the brand or product name.
The site I purchased my filters from is filters-now.com
