So, my truck has developed a ping under load and I've pretty much done everything to ensure that it's nothing on the outside of the engine that I can immediately correct (timing set to 10 degrees, spark plug type, spark plug wire routing, etc.).
I did the Seafoam treatment on my truck twice and the smoke show both times would be very impressive for Halloween purposes, so this lets me know that there is carbon in the combustion chambers/piston tops that is creating the ping.
I really like Gumout Regane High Mileage and I've used it twice, but the ping is still there, so it’s time to go to something a bit more extreme on working on carbon.
I'm not going to use 93 octane gas because that is a band-aid fix and not a true fix. Also, a piston soak would fix it, but that’s not exactly something I want to do on a V8. If it was a 4cyl, I would soak it overnight and be done with it.
Can someone recommend a fuel system additive that will work on this carbon buildup? A few come to mind, but my sole focus here is ping elimination.
I've heard that a bad cat also creates ping, so I'm not ruling that out.
Here’s what immediately comes to mind to put in the tank:
-B-12 Chemtool
-MMO
-Lucas Deep Clean – Yea yea, I know, simmer down I’m just asking a question! The bottle says eliminate knocking and pinging, so that’s why I listed it here.
-Techron
-Redline SL-1
-Seafoam
Suggestions (fuel treatment or otherwise) are welcome.
-B-12 Chemtool
-MMO
-Techron
-Redline SL-1
-Seafoam
