07 Silverado Classic. Fuel pump is in the tank. What is a reasonable estimate for parts and labor to replace the fuel pump?
That is rip off pricing. $536 for an aftermarket fuel pump? More like $200 retail on a Carter brand. And if they aren't going by the flat rate of 1.4 hours, they rip you off twice.
Not an endorsement.That is rip off pricing. $536 for an aftermarket fuel pump? More like $200 retail on a Carter brand. And if they aren't going by the flat rate of 1.4 hours, they rip you off twice.
Not an endorsement.
Many shops charge this much.
Rip off is the norm in the auto repair business. ( very few exceptions)
So what's the point of the flat rate system if that is the case?
Is the job really booked at 1.4 hours? It takes guys like 15 minutes just to get the vehicle in and up on the lift
Yep. Flat-rate assumes the tech has the tools and factory documentation to get the job done within that time. Many times, especially at a dealership, the goal is to hack and shortcut your way to beat book time. Customer gets charged full time, you get the keep the difference between book and actual time.
Fortunately, being a truck they are less likely to do an obviously visible hack job, like cutting a hole in the bed..... the goal is to hack and shortcut your way to beat book time.
Is 1.4 hours based on dropping the tank, or raising the bed?
OP: Please let us know how this ends. I'm in the $1000+ camp.
