FUCHS Silkolene 10w40 semi syn
IL
Should I use this rather than GN-4?
Which is the better oil for shared gearbox/engine? (air cooled/sheering and fuel delusion concerns)
In your case I don't think you'll find a magic bullet. The secret with fuel dilution is to fix the source of the dilution. Then change the oil at at lease half the manufacturers recommended interval after that. never seen and oil hold up to recommended intervals in any powersports equipment. I've run Silkolene, but only because I got a couple cases one time for a good deal. I think changing the oil often is at least as important as what oil you run. Run what's easier to get at a better price and change it every 20 - 30 engine hours max. That's my
