This Fram Ultra 7317 came off my 2008 Accord.
Oil was Amsoil 0w20 SS SM flavor, used all winter with many 1-2 mile short trips and with idling by my wife.
Mileage about 9000 but I'm Not exactly sure as the wife accidentally reset my trip B
which I use to track Oil changes....
Cut using the HF exhaust cutter
Here is my Blox magnetic drain plug
Small amount of sediment on the bypass valve. Yes it moved very easily.
media
Tiny bit of grit in the filter
taken apart
about 36 inches worth of media, took awhile to rip apart the end caps.
end caps and center tube
media and wire backing
so there is the wire backing and then I believe I had 3 tiny thin layers of this stuff.
or 1 big layer that I was able to carefully pull apart into 3 layers.
IIRC the amsoil filter I used last year had wire backing and then 2 distinctly different layers
refilled with Walmart clearance Royal Purple 0w20 and another Fram Ultra 7317
Off topic.... How is it that I can take clear pictures with my oily hands and my 2 yr old cell phone
BUT
Gumout's PROVE IT website only has pictures that were taken with a toaster by someone also having a seizure?
media
taken apart
BUT
