Ford's write up on their reasons for use of 5W-20
Originally posted by hominid7:
I don't doubt that your engine runs great on 5w20, but I don't think a '96 4.6L Ford was designed to run on 5w20, it was rather approved for 5w20 after the fact.
Ford started recommending 5W-20 for 4.6L Mustang GT engines back in 2001 I believe. Before that, it was 5w30. Since then they have "back-spec'ed" 5W-20 to the 1996 Mustang GT with the 4.6L engine which was the first year Ford started using this engine in the Mustang GT. I have a 1998 Ford Mustang GT and intend to continue using Mobil 1 5w30 in it. It runs great!
Originally posted by Rodbuckler:
Why 5W20 Oil?
Some customers are reluctant to follow Ford's recommendation to use 5W-20 oil in their engines based on the incorrect assumption that Ford and other Auto Manufacturers only recommend 5W-20 oil in order to increase fuel economy. Using 5W-20 oil can increase fuel economy by about 6/10ths of a percent compared to 5w30 and more if you are currently using a higher viscosity oil. This equates to an additional savings of 125 million gallons per year when used in all applicable Ford vehicles. Since its introduction in the 2001 MY, 5W-20 oils have saved up to 640 million gallons of gasoline in the U.S. or an equivalent 5.6 million metric tons of carbon dioxide emissions.
Based on what? Is Ford assuming no one speeds and people only drive on the highway at exactly 55 MPH? I think they are full of it.
Originally posted by vad:
And then how about all those tiny and tight Honda engines running perfectly in Europe on the specced by Honda 5w30?
Engines are NOT designed to run on one particular grade!!!
This myth is being repeated countless times and none here seem to care to challenge its validity.
Originally posted by JohnBrowning:
Oh I almost forgott!!! You know this whole thinner oils flow better debate??? Well not only does the oil flow into the parts,spaces and cavitys faster but it also flows out of them faster. This means that when under load the film is going to be squeezed out from between the two floating surfaces faster as well. Now under normal conditions this does not mean much but under shock loading conditions, over heating, detonation even momentarily this makes all the difference in the world. It could also make a huge diffence under high load low rpm conditions.
Someone mentioned that the Ford GT requires 5W50 oil instead of 5W20. Aside from the super charger the block,oil pump,rods, rod bearings,crankshaft,crankshaft bearings and all of the clearances on these parts is basicly indentical to the normal asperiated modular ford block. This alone should demonstrate that 5W20 is not the ideal compromise for this engine series! No one designs an engine around an oil the oil is always picked after wards as an after thought to meet minimum durability standards and to maximize fuel effiency. In the case of the GT CAFE is not an issue so only durability is an issue with the oil selection.
Excellent points!
Originally posted by Buford T. Justice:
Originally posted by GrtArtiste:
At start-up, aren't 5w20 and 5w30 virtually the same? If no, then please state why. If yes, then 5w30 is just as suitable as 5w20 in this area.
GrtArtiste
Excellent point! One would think 5W-20 and 5w30 offer about identical cold weather and first engine start up performance, but the 5w30 when hot offers much better hot engine protection. Also 5w30 hot is thinner than 5W-20 cold and 5W-20 hot is thinner than 5w30 hot.
I'm unsure what point you're making with the highlighted statement there, BTJ
In the case of PZ 5w-20 vs. 5w30 ..the difference in viscosity is 74% or 135%, depending on which way you go, across the board. Now it my not be linear all the way out but should be for a good practical distance.
I really am amazed at how the vast span, within which these two oils are identical at slightly different temps, is ignored.
Vad--anal? No. People are going to do whatever they want. If it's just for cafe reasons it's brilliant. If it protects the same or better and improves gas mileage slightly than it is better for all. If your car specs 5w20 and you choose not to use it for whatever reason that's cool. Nobody cares! It's your car. I don't care what happens overseas! Who cares that honda engines spec 5w30 in europe. This isn't europe. It's just an oil recommendation. Not a crisis.
I have been away for a few days so I am playing catch-up on this thread.
My skepticism about 5W-20 is only that why is 5w30 no longer any good? Many of the engines and autos now recommending 5W-20 use to use 5w30 without any problems.
5W-20 is a good oil, but I don't see how it is better than 5w30 except for a very slight and negligible improvements in fuel economy which are generally 0.5% compared to 5w30.
5w30 offers better hot engine protection since it is thicker hot than 5W-20 hot. Therefore the film on engine parts is thicker.
If the temperature outside is above 0 F (yes F not C), then 10w30 will work just fine in engines requiring 5w30. In fact, this is seen in numerous owner's manuals.
Of course going too thick is bad. There is no way I would run 10W-40 or 15w40 or 5W-50 or 20W-50 in my 1998 Ford Mustang GT.
All I am saying is what improvements are there by using 5W-20 instead of 5w30 other than very slight and negligible improvements in fuel economy?
I am thinking about going to Mobil 1 0w30 which offers the better cold weather and first engine start up performance and protection that the 5W-XX motor oils but also provides the same performance and protection of 5w30 and 10w30 hot.
whoops,
says me, before slowly fading into the background, terribly ashamed of my Eastern European accent.
BTW, it's not just Honda engines, that happily run on 5w30.
It's basically all engines.
They must be terribly behind the curve.
When the manufacturers spec a 0w-10 oil for their new engines, everyone, here, will say 0w-10 is too thin. You need the protection of a more robust oil like a 5w-20. You need the thicker 20 weight oil, especially when pulling a load. Only a 20 weight oil will offer the protection needed. The manufacturer just wants to improve the gas mileage a fraction of a percent, overall. Don't be fooled. Use a heaver, more robust oil like a 5w-20.
OK. In order to have a 5W rating, the oil must pour at -25 C through a small hole of which size I cannot remember. -25 C is -13 F. That is F'n COLD!
Now if 5W-20 is thinner across the board, why does it have a 5W rating? Shouldn't it actually have a 0W rating instead?
Also, if 5W-20 is thinner across the board, it becomes apparent why there is skepticism about its hot temperature performance and protection especially in sports cars and trucks that tow heavy loads.
Look at the spec's here use the pull down menus to find the multivisc oils and compare the 5w ratings. Not all 5w's are created equal ..just as 30 weights span a decent range. I mean it's not like they all are identical at the same temp.
Now for the upper end, yes, 5w-20 will be thinner then 5w30. So? How does that mandate that there will be less protection? Or rather, how does that mandate more wear? You're making assumptions that the 30 weight is the minimum needed for the task. Suppose, as we've known for sometime, that 30 weight was required to not go below a 20 weight over the oci? Just because they "may" have managed to reduce the shearing ...why does it mean that NOW you need that 30 weight ..when you didn't for about 30 years
(read this twice if you would like)
Also, Buford, as you go above 100C, visocities converge. That is, they become more "alike". What's a big difference at 0F ..is marginal @125C. I think it's a difference of 1.2 CST.
Let's wait untill the "Time machine" comes on-line.
Until then any speculation abouth the future would remain just that - a speculation.
And wait a second. Almost forgot.
OK, here we go.
Originally posted by Big Jim:
More B*S* from Ford.
There was a TSB published where FoMoCo clearly stated that the whole reason for the 5w20 grade switch is a marginal improvement in fuel economy.
I would like to see that TSB.
I don't remember seeing it when I was a Ford Service Manager. I do remember a TSB that talks about backfitting 5W20, but I don't remember it saying that the only reason was fuel economy.
I have a feling that you may be quoting it inaccurately.
Technical Service Bulletin
Ref Number: 02-1-9 Date of issue: Jan 21, 2002
Description:
Engine - Engine Oil - Recommended applications for SAE 5W-20 and SAE 5w30 motor oils.
Issue:
Ford Motor Company now recommends SAE 5W-20 viscosity grade for servicing most gasoline and flexible fuel vehicles.
Action:
All 2001 and 2002 vehicles where SAE 5W-20 is specified should be serviced at the recommended oil change intervals using SAE 5W-20.
This oil is an improved formulation to improve fuel economy.
There is the EPA letter that Blue99 posted. It says (broken up as you can read the whole thing)...
http://www.epa.gov/otaq/cert/dearmfr/ccd0006.pdf
"By using 5W20 [sic] engine oil in certification and fuel economy test vehicles, these manufacturers expect to realize a fuel economy benefit relative to the engine oils that they would otherwise have used."
So in a nutshell the only valid reason to going to 5W-20 over 5w30 was for fuel economy. I guess this was originally done for sales, but it doesn't mean much since the fuel economy improvement is 0.5% on average. So if I had a car or truck that got 20 MPG on the highway using 5w30 motor oil, the use of 5W-20 motor oil would yield 20.1 MPG. It is MEANINGLESS.
And Americans could care less about fuel economy. If we did, there would be no Mustangs or Camaros or Chargers or big trucks or SUVs, etc. We would be driving Yugos if we cared that much about it.
Originally posted by sxg6:
Geez Buford.. 5 consecutive posts within a 15 minute time frame is goin a little overboard.
I am a fast reader and am playing catch up thanks to a bad hard drive that required replacement and a Windows XP Pro reinstall, lol.
Prior to my Windows reinstall, I had a link in my bookmarks that had a really good article about 5W-20 protection. As I remember, the film created by 5W-20 was much thinner than the film created by 5w30. Anyway, the gist of the article was that if a dirt particle worked its way between the piston and cylinder wall that the film created by 5W-20 might be compromised therefore creating wear whereas the film created by 5w30 would suspend this dirt particle easily. I cannot remember what size this dirt particle was, but it was small. And I think, according to the article, that a dirt particle too big for the film created by 5w30 to be suspended would be too big to get between the piston and cylinder wall. If I can find that article, I will post it here.
Here is an article that is pretty close to the article I was referring to...
http://www.machinerylubrication.com/article_detail.asp?articleid=518&relatedbookgroup=Maintenance
Some quotes from it...
"Any abrasive particles equal to or larger than the oil film thickness will cause wear. Filters are necessary to keep contaminants small. The other side of the equation is oil film thickness. Thicker oil films can accommodate larger contaminants."
"If an SAE 50 oil at 260°F is as thin as an SAE 20 oil at 190°F, imagine how thin the oil film becomes when you are using an SAE 5W-20 and your engine overheats. When an engine overheats, the oil film becomes dangerously thin and can rupture."
"To determine if SAE 5W-20 oils provide the same level of protection as SAE 5w30 oils, Dagenham Motors in England, one of the largest Ford dealers in Europe, was consulted. SAE 5w30 is required for warranty purposes in England, and SAE 5W-20 is not even available. If SAE 5W-20 were better for both fuel economy and wear, why would Ford not recommend it for its same engines in Europe?"
"Certainly engines that have experienced significant ring and liner wear benefit from thicker oils. Thicker oil use results in compression increases, performance improvements and reduced oil consumption."
"The best protection against wear is probably a product that is a little thicker (such as SAE 10w30 or 15w40) and has more antiwear additives than the oils that support the warranty. The best oil for your vehicle depends on your driving habits, the age of your engine and the climate you drive in, but it is not necessarily the type of oil specified in the owner’s manual or stamped on the dipstick."
