Toro50cutter
Yes, same one.Is this the same transmission in the 23 Explorer? I test drove a new one of those and hated the way it shifted. It was not smooth at all. Super clunky.
For sure. But the 10-speed does allow these powertrains to do some (what 10-20 years ago would be considered) amazing things.I miss the 6-speed. It never had anywhere close to these issues.
This is true. Even with issues-I can't believe what a towing beast my 2020 F150 (3.5w/max towing) is when pulling my travel trailer up an 8,000 foot mountain pass.For sure. But the 10-speed does allow these powertrains to do some (what 10-20 years ago would be considered) amazing things.
They'll get it all sorted about the time that they outlaw ICE's.
Book mark this thread or start a new one and let us know!Thanks everyone. I will probably call and set an appointment in the near future. It’s incredibly frustrating but if Ford extends the warranty to 100,000… I could care less. By the time I get near that, I’m sure something would’ve gone bad and had some work done under warranty.
Will do!!Book mark this thread or start a new one and let us know!
What does the black box mean?We have done that TSB more than a few times with about a 10% success rate. End up putting a black box in it most of the time.
Reman transmissionWhat does the black box mean?
Reman assembly. Sometimes new, depends on what is offered for that particular application.What does the black box mean?
GM has done this extensively since the 6L series it feels weird getting used to it, but it seems to keep transmissions alive. now if they could design a TC that doesn’t suck.Watching the few videos out there on YouTube now, there seem to be 3 modes of failure associated with the CDF drum.
- wandering bushing slides or twists out of place, which closes off fluid pathways and/or sends a ~2” o-ring out of place.
- rotational bushing wear resulting in play in the assembly
- oil seal(s) can distort and come off of the inner assembly
Being that a fluid fix seems to have kept mine from getting worse, I’m wondering if the thin ULV working at high temps when under heavy loads is contributing to the bushing migration since the physical wear visible in one of the videos was pretty pronounced. This would be a solid call for finding a fluid with higher film strength or severe anti-wear additives. If the rotating assembly doesn’t scrape, maybe the pressed-in parts won’t shift and wander. I might consider doing another drain/fill this year - I’ll have an additional 40k on the fluid in mine since I did the first swap. Seems like it’s warranted. And while the Amsoil LV was too thick when I tried to swap in 6 quarts, the swap to back some of that out would have still left a partially thicker mix of oem ULV and amsoil LV, so if I drain/fill again, I’d be ok with a slight bit of amsoil LV in with the oem-spec ULV, say 2 quarts of LV with 4 quarts of ULV.
Again, I’m not seeing these problems show up from GM/Chevy owners. For that matter, I could attempt to use whatever the GM fluid is and see if it makes a difference.
GMs programming on this unit is very nice - it seems like ford tries to maintain more engine output mid-shift for more of a consistent, smooth, lux feel. GM on the other hand, defuels the engine notably until the shift completes, allowing it to hit the next gear before bringing power back in. It’s pretty quick and I didn’t find it obtrusive, though it’s a bit like comparing a softer camry to a notchy accord, back when they all had gears.
I’m thinking I’ll probably do the splash/fill this summer. I would not expect my dealer to “do the right thing,” unless the lawsuit paves a clear path to repairs if you’ve got it documented.
I thought they actually yanked a ton of timing and less so fuel?GM has done this extensively since the 6L series it feels weird getting used to it, but it seems to keep transmissions alive. now if they could design a TC that doesn’t suck.
I’m wondering if this tidbit is why HPL recommends to customers and uses the Green CC atf in their own 10R80s, even though they make the Teal which is the “correct” ultra-low viscosity according to Mercon ULV specs. The Green is definitely an LV fluid, but will have a higher film strength than the ULV.Being that a fluid fix seems to have kept mine from getting worse, I’m wondering if the thin ULV working at high temps when under heavy loads is contributing to the bushing migration since the physical wear visible in one of the videos was pretty pronounced. This would be a solid call for finding a fluid with higher film strength or severe anti-wear additives.
it is timing, you’re correct!I thought they actually yanked a ton of timing and less so fuel?
So… my very first attempt was doing a drain-fill with amsoil signature series LV, a very good fluid. As noted, I was able to get more than the normal fluid amount out by idling it for 15-20 seconds or so allowing it to pump some air in and foam up the fluid, which drained an additional 1-2 quarts. (Transmission is under no load, and it’s plenty wet with fluid at this point).I’m wondering if this tidbit is why HPL recommends to customers and uses the Green CC atf in their own 10R80s, even though they make the Teal which is the “correct” ultra-low viscosity according to Mercon ULV specs. The Green is definitely an LV fluid, but will have a higher film strength than the ULV.
I’m hoping for some decent weather this week so I can put my PPE deep pan on and swap all the fluid with Green CC.
Right, you said that before and I trust your experience, but there’s got to be some other variables going on. Just wondering, when (if ever) was your trans software updated? I took mine in May ‘22 for the occasional clunky downshift and of course the dealer claimed they couldn’t duplicate my issue, and would not do the update, even though I would have paid for it.So… my very first attempt was doing a drain-fill with amsoil signature series LV, a very good fluid. As noted, I was able to get more than the normal fluid amount out by idling it for 15-20 seconds or so allowing it to pump some air in and foam up the fluid, which drained an additional 1-2 quarts. (Transmission is under no load, and it’s plenty wet with fluid at this point).
The shift quality was diminished with the thicker fluid and the adaptives didnt figure it out or weren’t able to adjust to it. Doing another drain fill (traditional, no extra idling) it drives better on ULV (again, here is where I added 1-2 oz of LG red). I would not do a full change to an LV. If I do the approximate math, 1/4 of my current mix is LV, and the rest ULV - and it’s driving very well.
the feel was “blocky” enough with half LV fluid that I’d probably start moving to buy something else if that was the only solution.
Our one work truck is a 2018 and while I never got to drive it, the crew said described all the stuff you mentioned above....and eventually at 55k miles it got too unsafe to drive because it would be in neutral trying to leave stop lights. It was at the dealership for about 3 months and they tried to rebuild it apparently and it didn't work, so then they waited a while for a new one. They are currently driving it but they said "it's a lot better but still clunks a lot".Hey folks. I assume most anyone who pays attention to Ford or owns one is aware of the variety of issues that the 10R80 transmission has. Over this past summer, Ford released TSB22-2428. It provides guidance in diagnosing and ultimately fixing the issues associated with this transmission. Some of the many complaints seem to revolve around jerking while downshifting, loud “clunking” while downshifting/upshifting, and issues while either accelerating quickly or braking quickly. These issues tend to sound similar to the others stated, specifically to jerking and clunking noises.
Has anyone had success in getting Ford to begin fixing or diagnosing their 10R80?
I’ve always noticed my transmission is usually smooth with the occasional hiccup, but in the past 2 months I’ve experienced new “clunking” noises while my transmission is in 2-4th gear (particularly in a parking lot) as well as jerking and holding onto a gear while braking. I’m sitting at about 38,000 miles and am beginning to think my trans is starting to have some problems.
The rest of this truck has been excellent. I can’t complain at all. But with the current CA lawsuit, I figure it may be worth having this documented. However, we are all aware of how dealerships will simply say, “It’s common.. it’s not out of the ordinary… etc”.
My 2005 4.8 4L60E even does this. It's annoying but whatever it takes to keep it from dying I guess.GM has done this extensively since the 6L series it feels weird getting used to it, but it seems to keep transmissions alive. now if they could design a TC that doesn’t suck.
