Originally Posted By: itguy08
Originally Posted By: rodinator1234
Aftermarket companies are currently struggling to increase performance in direct injected engines. There are no aftermarket HPFP, no aftermarket injectors to help fuel increased fuel delivery. Tuning is a struggle. It’s apparent there’s many here who don’t understand the design of modern direct injected fuel systems. They are so very similar to high pressure common rail diesel systems that share many of the same issues tuning and failures.
Really? Livernois in MI is doing great things with the Ecoboost 3.5. IIRC they were getting 500HP out of it back in 2010-2011. I believe that they are also doing Ecoboost 2.5 (Mustang, Focus ST/RS) work as well.
Both Livernois and RTR/XDI make
High Volume Pumps for Ecoboost applications. They are pricey though!
The tuners have been tuning the Ecoboost 3.5 since it's debut in 2009 with great results.
You are correct, there are lots of companies that tune for Ecoboost engines 3.5L, 2.7L, 2.3L, 2.0L, 1.6L. Tuning alone will not allow E85 use, E30 is generally the maximum safe ratio. The topic was about E85 not Ecoboost tuning I was relating to tuning for E85. E85 can be used with fuel system hard part changes and until recently there’s been no options.
