FL820s alternative
North Carolina
Hey all,
I'm looking for an alternative to the Motorcraft FL-820s. The problem I am having is that the diameter of the filter is about a quarter of an inch or so too large to fit comfortably where I have to install it. Length is not a problem, however. Is there a filter that has the same specs but is in a smaller diameter size?
Thanks!
Do you drive the car up on ramps? If so, after you stop turn the wheel a little to the left. This may give you extra room to get the filter out.
He said it was the diameter of the filter, not the length, that is his issue, so the new *improved* FL820S won't buy him anything.
Sorry I can't help otherwise...
B1422 Baldwin. It's got a 20psi bypass.
In Wix it's more reasonable
Part Number: 51378
UPC Number: 765809513785
Principal Application: Acura (88-05), Sterling 827 (89-91)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.170
Outer Diameter Top: 3.152
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 9-12
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 300
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 17
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.940 2.630 0.235
B160 Baldwin is the newer GM filter 3" diameter (already mentioned).
There's one for an Isuzu, but it doesn't appear to xref to either WIX or Baldwin (the only two I checked).
P550389
Lube Filters Product Attributes
A - OD (Inches): 3.15
B - Thread Size (Inches): M22 X 1.5
C - Length (Inches): 3.94
D - Gasket OD (Inches): 2.48
E - Gasket ID (Inches): 1.99
Relief Valve Setting (PSI): 8-11
Anti Drain Valve (Y/N): Yes
Product Type Description: LUBE SPIN-ON FULL FLOW
Primary Application: ISUZU 8941145840
Product Group: F
