Fixing Briggs and Stratton 6 HP Quantum lawnmower engine
SE British Columbia, Canada
I recently solved the no-start issue on a 6 HP B&S mower engine. It’s 20 years old and was the series when they used a red bulb to prime the engine rather than have a real choke assembly. This engine is overly susceptible to a no-start condition due to old gas and the carb can get clogged up easily.
The red bulb actually pumps air to cause a venturi effect to bring gas from the bowl into the carb and uses a large plastic plate assembly to house the bulb and priming circuit.
You tube videos suggest doubling up the gaskets between the carb and plate, and removing the bulb assembly and cleaning it up. Those things did not work here. I also removed the bowl and sprayed the carb with carb cleaner with no improvement.
The easy way out was to order a carb kit made in China that came with a new carb, plate, fuel hose, shut-off valve, gas filter, air filter, governor springs, spark plug, blow by hose, clamps, heavy duty air filter cover all for $30 US. It runs fine now, and has the shut off valve and fly screen filter installed. Incidentally, this is for the widow of the LEO who has a place down the street. Here are a few shots. Enjoy.
It is sad that it is just easier to replace than repair.
I had the same answer from local shop on maybe a snow blower or thatcher. I inquired about a rebuild kit and looked on online. Parts kit was like $50 with shipping, Shop said the same plus labor and that they pretty much just get new for less cost. Same deal about $30, came with everything including new lines, a couple bolts and ran great.
Nice job and good karma for you helping out.
You're a real gem to put a fuel filter on this. Bugs me these never came with one to begin with. That baffle on the new one really helps to line up the gasket it appears. I honestly didn't know how long these Brute's have been made. I convinced my Dad to buy a self propelled push mower & these were being sold at our local WM that is a 6.25 HP. He put many hours on this & then gave it to my brother which knows how to ruin everything. Not pictured is a 2014 6.75 HP Brute I bought from Menards brand new & gave it to my son for his property a few years back. Plan on restoring this one below the best I can afford to eventually. ha! Again, I didn't know these were made 20 years ago. cool & good job!
I had the same problem with a barely used 25 year old mower my dad bought. A new carb made it run like a champ but it still required a spritz of ether to get started. I sprung for a complete new primer bulb plate for $20 and that fixed it even though I couldn't see any problem with the old one.
Looks like I’m getting some variation on the repeatability on the red bulb air pump. Some you tubers have mentioned to control the torque bolting the plastic plate to the carb, because flexing of the plastic plate ruins the seal agains the carb. I’m thinking of backing off the torque and using an in - lb torque wrench to make sure all three bolts get the same amount. Anyone know what’s the proper value?
I have had lots of those Briggs quantum primer/air filter bases warp resulting in no primer action. Sometimes doubling the gasket up will fix them and do NOT over torque the screws, you can ruin a brand new base plate right off the bat by doing so. I've had to use 2 gaskets on a brand new base plate as well to make it work. I much prefer the ready start auto choke on these. The very first quantums were manual choke and had a metal base plate, they should all be made of metal this problem wouldn't exist at all, but I guess if that's what it takes to sell parts.... A few years later they went to the primer style but it wasn't like this, it was a big primer button that mounted to the side of the fuel tank and had a small line that went to the port on the carb if I recall correctly, that style worked well.
Had the same engine. All I did was double the backing plate gasket and it worked fine. Yes, those plates flex way too much causing air leaks. Crappy design. Take the breather tube off the backing plate and let it blow. Put a rubber cap on the backing plate. It will save you're air cleaner. The engine doesn't need it. Did it start rod rappin yet ????. Usually louder under load. That's the 1st thing it will do when the engine is on it's way out. Just add heavier oil or STP blue bottle to the 20 oz oil fill. 20W50 or 30wt with blue bottle. That will keep her going a few more years. Frequent spill and fills will dramatically increase life. Sharp blade will reduce drag on engine too.,,,adding to engine life.... Those flatheads can go a long time if you maintain them. Best of luck with the double gasket. they are a PITA to set just right. Run some stabil fix in it every so often to clean carb and head. Works well :)
