Seeing how Mopar started using ECM/PCM controlled charging before everyone else did, I can see a dealer tech putting the blame on the PCM since there isn't a hard and fast test to rule out a bad voltage regulator. Toyota and Honda also use identical Denso alternators.
The PCM could be using PWM to regulate how strong the field/excitement current within the alternator and the bench test isn't looking at how the alt behaves under PCM control.
