This has been bantered about in a few different threads.
At least one sceptic says filter companies don't pay warranties.
A couple others think that what they pay is for the filter itself.
It's to bad they don't do the research before they jump to conclusions.
One can go to the filter companies websites, look in their catalogs for their printed warranty, or call them to find out their warranty..
The basic language you will see is something to the effect of " will restore the engine or equipment to a condition equivalent of that existing just before the failure."
They pay for the engine should the filter be mismanufactured.
Should you ever send in a filter because your engine has had a problem, do not cut it open .
The lab will want the filter intact in order to test it.
Should you feel that there is some sort of filter company conspiracy, you can mark your filter before you send it back.
At Champ, and I suspect the other filter companies as well, you have 60 days to request your filter back after they have tested it. If you do, then you can send the filter out for additional independant lab testing at your own expense or your lawyers.
Filter companies will request the repair bills should the filter test or be found to be defective by the filter company that manufactured the filter. They or their insurance company will then reimburse you.
Now some of the things they will need to know are :
The nature of your complaint.
Make, model, and engine type of the vehicle.
Total mileage on the vehicle.
Mileage since last oil change.
Type of oil and oil grade used.
An oil sample would be of great benefit as well.
What will happen once the filter is logged in and received is a warranty report will be started and that the part number will be checked against the correct cataloged part number for the make, model, engine type.
A visual inspection for dents or holes in the can and a check for collapsed center tube will be done.
The threads and gasket will be checked to make sure they are correct for the catalog part number. Threads will also be checked for alignment within the backplate.
Then the lab equipment will be used to test the filter.
As an example: You claim the filter leaked and caused the oil to run out and then the engine failed.
The filter will be put on an impulse test machine which will pulse the filter a minimum 5,000 times ( simulating cold engine starts at a high pressure rate). If the filter doesn't leak, no warranty will be paid. If it does leak, they will pay the claim.
If you claim the engine failed and the filter never leaked advanced testing will be done. Which is why they need the filter to be intact.
When the testing is done you will receive a cover letter and an explaination of the tests done by engineering. ( This is Champs policy and I suspect the same with the other filter companies).
