Filter change intervals
Originally Posted By: Clevy
Originally Posted By: LScowboy
Originally Posted By: surfstar
2) It has been proven that wear is higher with fresh oil following a change vs later in the OCI
that's ridiculous
Quote:
4) New oil can have contaminants and that 'used' stuff in your filter may actually be cleaner, particulate-wise
that's beyond ridiculous, if we are referring to major brands and not "sleazy convenience store oil" - Pennzoil, Mobil, Castrol, Quaker State, Valvoline, etc. are filtered to a crazy degree, my bottled spring water I am drinking right now likely has more particulate than these high line oils, and used motor oil does by many times over. In fact, it is particulate that is responsible for most of the opacity and dark color of used oil. Black carbon is a particulate!
So the sae papers dnewton derives his data from is rediculous.
I'll explain it to you so you can understand.
Oil puts its own anti-wear layer on over time. When you change your oil the new oil strips the previous anti-wear layer off and puts on its own,so during that period wear metals increase. It's not "rediculous",its proven,to automotive engineers anyways.
So if you consider yourself to know more then by all means educate me. Until such time I'll consider your posts rediculous,and posted by a blowhard bitog know it all,who has no data.
Not trying to sound sarcastic but if this is true, which I will not dare Q?, then why don't we just keep using dirty (used) oil?
And, while on the subject, if a filters media is "supposed" to filter better as it gets used, why "even" change our oil filters?
The oil layer theory makes sense to me, in a way. But, if a filter gets better as it's used, how used will it get before it goes into bypass? Why not just avoid the bypass guessing game and just change it at every OCI?
I am going to change it no matter what, but others might be curious and want to know.
Most people do indeed change the oil too often, or not run it to its full potential. Oil generally shears with use, so as the miles pile on, its functional properties (many of which are not influenced by filtration) begin to degrade and you eventually end up with oil that is beyond its useful life.
Filter media becomes more efficient over time, to the point where it begins to bypass. This is why it's very important to take the filter and the vehicle into account when prescribing a filter change interval. In your case, with a MC filter, I think your FCI of about 7,500 miles is a good one. I would not, for example, recommend you run a MC filter for 15,000 miles. I would also not, for example, recommend changing after only 3,000 miles.
You could go to the extreme, and change your oil filter every 1,000 miles. Why not that? Sure, it's wasteful of time and resources, but you know it won't be bypassing after only 1,000 miles! The filter media and engine must be taken into account when prescribing a FCI. A Japanese OEM filter can easily go 10,000 miles or more, because of the nature of the media and how they're designed. Conversely, I wouldn't run some third party filters (like a Purolator Classic or a Motorcraft) more than about 7,500 miles...maybe 10,000 at the most. Honda recommends filter changes at every other oil change, but if you're following the MM, that's an FCI of about 15,000 miles; there's no way I'd do that with a Classic or a MC.
Only knowing the engine and the filter would I attempt to recommend an FCI. If you changed your oil every 3,000 miles with a MC filter, I'd recommend you use your MC filter for two oil changes. If you changed your oil every 6,000 miles with a MC filter, I'd recommend you change the filter at each oil change. A filter change shouldn't necessarily be tied to an oil change. We do it simply out of convenience.
Your plan of 7,500 miles for each (oil and filter) is a good one. You're getting most of the life out of each product without changing either one too early (at least in my opinion).
Sounds like we could do well by changing the filter halfway through the oil change, and the oil halfway through the filter change! lol Or NOT! Makes more sense to me to try to match up the filter & oil change intervals by their rating, vehicle and type of driving done. Such as M1 EP with M1 Extended Drain filter as an easy example. Then, of course, change them at the same time.
I am a scientist and engineer by day, and although I find myself wanting to probe as deeply into the science and physics and engineering on every technical issue, I have realized in my old age that sometimes we get so mired up in the "science" of things, that someone needs to just dope-slap us upside the head with some good old common horse-sense!
Sort of like not being able to see the forest for the trees!
This is why my favorite data is fast becoming, not facts and figures and theory, but real world information, like KCJeep finding an oil filter that quieted his Jeep, when the others he tried would not, that impresses me far more than some beta level of filtration, or metal caps on the end of a filter etc.
I think KC is moonlighting as a MC spokesperson. He gets paid with MC oil filters.
First time I ever heard a scientist or engineer say something like that.
Watch it. Look at what happens when Spock goes emotional? The Enterprise ends up usually spiraling in towards the ground in a decaying orbit until he regains composure.
Speaking of which, I could use one right now. The PureOne I just put on at last OCI a couple hundred miles ago, thinking it'd be okay in summer is NOT!
So either I'm going to spin on one of the double ADBV filters I wanted to test or I'll just go get another FL-400S for the rest of this run.
Who'da thunk you'd get DEATH RATTLE out of a good filter like a PureOne in 80 degree temps? That is just how picky this particular Jeep is.
I guess I do have a Mopar Motorcraft clone except with nitrile not silicone ADBV, that would probably work too.
I took a poll and everyone voted to install the STP S8316!
That was one fast poll! One literally that is.
