Originally Posted by gfh77665
Originally Posted by 390pi
3.6L (if you find one) works best with 3.55 gears.
Most gearing for all motors (except 3.21 with diesel) was 3.21, 3.55 and 3.92
Thats the exact same combo I got on my 2019 Classic. It works great together. 21+ mpg too.
I've got a 2017 Ram 1500 QC, express 4x4 with the 3.6L and 3.21 gears. It was quite the deal used when I bought it in April 2018 with 12K miles on it for just over $23K+TTL from a small Cadillac/Buick/GMC dealer lot. Basically why I bought it, but two years later w/ almost 50K miles on the ODO, I still love the darn thing.
My brother bought a new 2019 classic almost like mine, but with the 3.55 gears. Each of us driving both, you can feel exactly zero difference between the 3.21 and 3.55 gearing with the pentastar engine, but on paper, the 3.55's can tow quite a bit more. My brother tows his ~4000lb boat around and opted for the 3.55s for towing.
I haven't looked around, but used pentastar powered Classics didn't used to be a hard find in my area, but maybe people are snatching them up now?
If buying a used Ram 1500 of any flavor older than 2yrs or so in rust belt climates, one thing you WILL run into is seized parking brakes. Before you drive it off the lot, etc, mash test and release the parking brake several times and check for cable sag underneath. They seize up where the lever actuators poke through each rear backing plate. A dealer OEM fix is in the $1200 range. Mine are partially seized. I have them somewhat freed up but have to do more work on them. I think this parking brake (in the rust belt) situation is the only draw back to Ram 1500s.
In terms of what 1/2ton truck is best? They're ALL good IMO. They've all got thin flimsy body panels. Thin paint. Cheap plastics. Crazy expensive and complicated electronics. What vehicle doesn't these days? For what ever reason, lower optioned Rams seem to have the least resale value, thus can be a used deal.
