Originally Posted by StevieC
With regards to Ravenol versus a C3 rated oil, why does it matter? C3 rating should make all oils perform to at least the minimum level set out by the C3 spec and they are showing that their oil meets and exceeds the performance of the C3 oil they tested it against even though they are using a thinner weight which would also yield a lower HTHS. This lower HTHS rating should according to some yield less protection which can lead to more wear.
It matters because a C3 oil is designed for applications that require an HTHS of >=3.5cP, which this application doesn't.
C3 is a low SAPS spec, and, like with the API, denotes a minimum level of performance. One of those parameters is a minimum HTHS, which obviously the 0w-16 doesn't meet.
But, getting past that:
They tested a 0w-16 and a 5w30 C3 lubricant in an application that calls for 5w-20/0w-20. They tested a 0w-16 that's PAO-based with no VII's (so it won't shear) and then provided some graphs with no scale that showed:
- Some small (going by the dimensionless graphs) wear performance benefit
- Less TBN loss (completely normal when compared to ANY low SAPS oil, so completely meaningless)
- Less viscosity loss, which is again entirely expected, since the oil has no VII's; it's a straight-weight that gets to carry the 0w-xx designation due to its PAO content.
In an application likely developed on a non-PAO 0w-16 (since that's the direction Japan has been going for ages) or even thinner oil, it should be no surprise that a generic C3 low SAPS 5w30 didn't prove to be a better lubricant than a shear-proof 0w-16 that does not abide by the constraints of the C3 designation for additives. This was a predictable outcome.
If XOM or Sopus had put this out in the same manner folks of each crowd would be all over it, but because it's not a mainstream branded oil with enough supporters here, it is immediately cast aside just like Amsoil, Redline or some other oil that isn't used as frequently.
That's malarky. Sure you'd have some folks cheerleading the claims and you'd have the same group, including myself and Shannow, injecting some much needed reality. These threads all go the same way, it doesn't matter whose name is on the bottle. Some people just seem to get a bit overly sensitive when it is their brand of choice with its feet to the fire. That's not intended to be a dig, it's just par for the course when one's personal preference is the one being criticized.
