Originally Posted by Ihatetochangeoil
The NEWEST car I have is 15 years old. It runs, stops, steers and sounds like a new car, and leaks nothing. THAT being said, it is BITOG maintained; I've got slightly more than 1/2 your miles...150K+, I've replaced valve cover gaskets, oil pan gasket, transmission oil cooler lines, PS fluid lines, heater hoses & heater core, serpentine belt, water pump, A/C compressor & evaporator core, etc., anything that leaks or breaks...
I agree with simple_gifts, it is simply Old car issues. My opinion is that no amount of oil change frequency is going to preserve old valve cover gaskets. On my "old car" I love that everything works and the icing is it's paid for.....and yes, it has a few dents and dings and I could care less who parks next to me....I love it. BTW, I use Amsoil for all fluids, even grease and PS fluid, and I change oil ~10-12K, after all, I'm using the best oil on the market.
Simple facts: older cars REQUIRE more maintenance.
Now this^^^is a post I like because it is truthful. I can't stand the...I have 300,000 miles on my car and all I've done is oil changes, garbage. It's not real. Give me the real story, the whole story, every time.
I took a Honda Accord to 289,000 miles. It takes a whole lot to get a car that far. Everything eventually leaks. And when it does? You can either fix it or don't. It's that simple.
Right now we have a 2008 Honda CRV in the family, it has 139,000 miles...the tranmssion leaks, and the rear differential leaks. I won't fix either because it leaks where the units split in two, it's not a simple repair like a valve cover or pan gasket. So I'll just make sure the Fluid is full and drive. But if I could fix it I would.
