So I went to the Lubrzol site and put in the different oil specs of different oils. I put in API SN+/ACEA A5/B5 and various Mercedes Benz oil specs that Mobil 1 ESP 5w30 has. The Mobil 1 ESP has more ant-wear and anti bore wear additives if I go by the Lubrizol site chart. Then say Mobil 1 extended 5w30.
I own a new Hyundai GDI Turbo and all they spec is API SN and ACEA A5/B5 and thats it in 5-30 or 5-40. I have over 5% fuel dilution @2,000 miles @polaris Labs with Amsoil SS 5-30 in late summer. Minnesota winters are coming up so lets increase it 2 fold @2,000 miles I am looking for a cheaper oil because I will have to dump early. If I look at all the specs Amsoil approve to with their 5w30 SS they don't have any mercedes benz specs that have greater antiwear/anti soot,anti piston deposits, and anti sludge ect..... Mobil 1 ESP does have 3 and I can get it cheaper. I have read here that ESP has a good chunk of POE to get these ratings vs Amsoil that has more PAO. ESP is rating for gasoline engines. Can I go by Lubrzols chart to find a better oil through check marking approved specs? I have also found that Mobil 1 ESP beats any Pennzoil Euro L and all their other API Dexos 1 Gen 2 Platinum and Euro oils. Even though Mobil 1 ESP does not have a Dexos 1 Gen 2 rating, it has 1,000 ppm calcium and low sodium, so it should be a LSPI oil that I need/want/have to have since I get full boost at 1,700 rpm . Your thoughts please
