Originally Posted By: PandaBear
Originally Posted By: MinamiKotaro
The passengers would "merely" suffocate.
Like they would inside an airplane. There are mature technologies to deal with that.
What technologies would those be?
Just curious. When an airplane loses pressurization, the outside pressure is about 25KPa (vs. 100KPa at sea level). Instant vacuum is far, far worse than a depressurization at 35,000 feet.
Further, the airplane is going to descend, rapidly, to an altitude at which breathing is possible.
This isn't possible inside the evacuated tube. It has to maintain vacuum to function.
So, what mature technologies exist to allow people to survive in a vacuum for the length of the trip?
Current O2 masks won't work. Within seconds, our tube passengers will be suffocating, because they can't inhale (there's a vacuum outside their lungs, so inside their lungs won't be lower pressure, as it is ordinarily). They will be continually exhaling, unless they can get a high pressure mask, which isn't commercially available. If they survive those few seconds and don the pressure mask, they might not have their lungs rupture from the internal pressure.
Then, they merely have to deal with the phase transition of the water in their blood and tissues from liquid to gas... At that low a pressure, depending on temperature, a condition called ebullism,will cause tissue swelling and bruising due to the formation of water vapor under the skin; at worst, it can give rise to an embolism, or blood vessel blockage due to gas bubbles in the bloodstream.
So, sure, they could wear pressure suits, like military pilots do above 50,000', which would require some training and careful (read: expensive) fitting, and then they could survive decompression of the "car" in the tube...but it's not exactly viable, or mature, technology...
