"Any FF over $2 is a waste of money." I beg to differ!
The 1988 AC Filter/Detroit Diesel ASTM study determined that particles in the 2-22 micron range cause most engine wear.
PureOne media min/max pore size, per Grease's Mercruiser study: 11/25 microns
Hastings media min/max pore size, per Grease's Mercruiser study: 21/46 microns
I'm guessing the PureOne might cost $2 more than Hastings, or all of $20 over a typical 5 yr vehicle ownership. If a slight impregnation of dirt doesn't significantly harm flow, hypothetically cutting the PureOne's pore size in half (a random speculative amount) to 6/13 microns, that could certainly explain improved filtration. But in the end, the proper term for this is "clogging." The benefits of bypass filtration become quite clear here, although the logistics and cost-effectiveness of same are less clear.
[ August 22, 2004, 08:14 PM: Message edited by: TC ]
