Took the plugs out and gave it 3X 10 second burst on the starter, put them back in, remembered to re-connect the plug leads this time, skooshed some butane in the air filter and turned the starter and.....
nothing happened.
But it caught on the second attempt. Seems to run OK.
Rear drivers side brake locked on. Maybe I parked it with the handbrake on (DUH!) but the brake parts were treated with sunflower oil and aluminium, which I've got away with in the past, but maybe not before such a long-long-hot-wet time. Its a pretty strong glue in the wrong place.
Should probably have stopped and taken it apart but a bit of to-and-fro, in-and-out, with some noises, and it came free.
More alarming cracking noises on sharp RH turns during the (otherwise OK) test drive so I'll take it apart later. Maybe I've lost another brake shoe lining, though I dunno why that would be more manifest on turns.
I did some half...er...baked blotter spots off the dipstick before starting, after 5 mins of idle, and after a short test run around campus. Hadn't planned this and only had scrap paper (printed on the back) to hand.
I thought I might see settled-out debris going back into suspension. I never really know how to interpret those things even done carefully, and I can't see a difference here. They all show a central debris ring and, 4WIW, otherwise look velly clean. And cheap.
To the eye I'd say the ring pattern looks clearest with transmitted light, to the camera clearest with incident light. Go figure.
nothing happened.
