Originally Posted By: 3Toyotas
Originally Posted By: StevieC
Ok, I didn't understand the first post... I see what you mean now...
Maybe the oil is running too hot and needs an external cooler.
What kind of driving is done with this vehicle?
My Santa Fe has an external cooler and it always looks like it did when first put in all through the OCI.
I beleive the Sienna van is basically the same drivetrain as the Camry, if i'm not mistaken. And i know the camry is hard on trans fluid, and it's more than likely running too hot.
I know my daughters Scion TC needs some attention with the WS fluid, as it's dark marooon in color already with only 17k on the clock. It's the 2.4L / 4-speed auto, which is the same in the camry.
It's got to have something to do with the trans being so close to the motor, with all that heat in there.
It is a 1992 Toyota Previa with the 2.4L 2TZ-FE 4-cylinder engine. RWD, 137HP hauling 5000 lbs.
My dad drives it very, very gently. He rarely goes over 60 mph on the highway. However, he does have a nasty habit of manually shifting it into 2nd on a daily basis to utilize the "engine braking" function.
