Anyone run a Ea020 in a newer Honda?
Quote:
Part Number: 51392 or 1392
UPC Number: 765809513921
Principal Application: Acura Integra (86-87), Honda (80-87)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.141
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 275
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 19
Quote:
AMSOIL Center Expansion
AMSOIL Prepares Major Expansion in Production Capabilities
From humble beginnings in a single small building, AMSOIL INC. has steadily grown to more than a half dozen buildings in three Superior, WI locations with more than 650,000 square feet of office, production and warehouse space. AMSOIL recently announced a $15 Million Expansion Project of storage, blending and productive facilities in Superior. The new expansion project to lay foundations for future growth is now set in motion. Highlights of the expansion project are as follows:
Increase annual blending capacity by 2.5 times.
* New bulk unloading area will be constructed on the west side of the building for rail car and tank truck receipts. The structure will provide covered containment for the staging of up to six (6) rail cars with capability to load/unload three at a time versus our current one car at a time. The area will also provide tank truck capacity for loading/unloading of four (4) trucks.
* A new bulk tank farm will be built on the north side of the building. The tank farm will be enclosed to improve operator safety, eliminate storm water contact with the process, and reduce weather-related temperature variations in the product.
* An indoor tank farm will be constructed to store lower volume base oils and additives as well as bulk finished products
* Existing packaging lines will be relocated from Winter Street building to the AMSOIL Center.
All existing personnel and functions will be moved from the Winter Street Plant to the AMSOIL Center.
