Originally Posted By: skypants
Originally Posted By: ltslimjim
I definitely believe that E85 burns hotter than E10.
Incorrect, E85 burns cooler than gas. It contains more oxygen, burns slower, and much cooler. EGTs drop by several hundred deg. with E85. It is a much safer fuel for your engine than gas.
E85 burns slower than E10? How does that explain why fuel economy suffers using E85, even in a flex-fuel vehicle? From my experience, it increases your consumption rate.
It; E85, has less energy than E10 per gallon. You're talking about basically an alcohol diluted with some gasoline and additives; which has less effective BTU/gallon that gasoline does. Of course, when you use the E85 as a racing fuel it's able to run super rich without detonation compared to gasoline(more volatile and 'explosive', not desirable because you want clean/even burn). The less energy per gallon, in E85, can thus allow for the feel(actual as well) of increased power for instance and this may be in relation to the effective octane increase(105 standard) and no drag in timing/spark advance is created from lower octane gas as we know it today(leaded fuels in the past is another story) and so it may burn cleaner as a result and is less volatile than gas, so THAT (to me) is why a car with higher octane needs and/or the ability(injector capable/compression ratio/tuning etc; as well as flex-fuel apps) to generate more performance/response with E85.
Maybe we're talking about 2 different things. E85 is consumed at a faster rate than gasoline(even e10). More movement in general typically means more heat is created, so while it may burn cleaner and at a more 'stable' rate, it doesn't mean it runs cooler alone. I'd like to talk about the particulars on that.
I'm a noob, so take what I question with a grain of salt. I'm sure someone else can explain it better.
http://en.wikipedia.org/wiki/Gasoline_gallon_equivalent
http://en.wikipedia.org/wiki/Gasoline_gallon_equivalent#E85
