Kestas
Staff member
Originally Posted By: Cujet
I'd like you guys to know that it's possible to match a diesels thermal efficiency with E85. I'm not saying it's good, as there are problems with such a setup. Just that it's possible...
Pretty impossible to make such a system "flex" fueled
That's probably true, if we don't have a viable way to change compression ratio. However, interestingly enough, highly variable intake valve timing can "virtually" adjust compression ratio, and could go a long way towards making such an engine remotely feasible.
Just because we can does not mean we should. I'm in favor of the research, but that's about it. I'm not convinced E85, in it's current form, should be a mainstream fuel.
I've read where the automakers are toying with the idea of making variable compression engines by varying the position of the crankshaft on-the-fly relative to the head.
