If it where me I would have dumped it at 500 miles. I think the Havoline with the high moly content is what I would use. Yes I would dump it at 2000.
I'll do one after a couple thousand miles too. I see some peoples oil consumption continue to drop until they have several thousand miles on their car. That means some in-place-final-machining is still going on.quote:
Originally posted by TallPaul:
Seems to me that with a new engine, breakin is in the first 20 or 30 miles if done right, so dump after breakin, then I would probaby dump again after a couple hundred miles.
You came to BITOG for a consensus?!?quote:
Originally posted by texasproud:
Thanks for all your comments and there does not appear to be a concensus(really ?) as to which direction to go...drain or run it.
I(and lots of BITOG folks) take Terry's opinion very seriouslyquote:
Originally posted by Laminar Lou:
I had the same dilemma, I have an 06 Odyssey and towed 2000lbs in 100F+ heat for 1200 miles with the break in oil still in it. Right after all the towing (at 3600 miles), I did an oil sample and found that the oil was starting to shear. I dumped it and put Chevron Supreme 5W20 (I looked everywhere and couldn't find Havoline 5W20).
Honda is adamant about that factory fill oil, so there must be a good reason they want it in. But if you use an oil that has the same chemistry (Havoline or Chevron) you can cheat and dump the oil and I don't think the engine will notice. I probably would have kept it in, except the towing caused some pretty high wear numbers and I broke down and sent it to Terry Dyson for analysis. He instructed me to dump the oil, so I did. And now I sleep good at night (well I have a 9 month old daughter, so when I do actually sleep it is good).![]()
I think the short trips will break in your engine faster. My engine had 98% short trips (less than 5 miles), with 2 really long trips towing a ton.
