Different oils have different "signatures". The purpose of Used Oil Analysis is to trend data (typically with the same lubricant) so that you can pick-up anomalies, such as a rapid uptake in a certain metal that might point to a component going sideways, signs of an air intake tract leak (silicon increasing), coolant ingress (sodium) and the continued serviceability of the lubricant (iron is below the condemnation point, as it tracks with miles/hours, TBN and TAN still look decent, fuel isn't insane...etc).
Copper for example is easily chelated by polar base oils like esters, which shows up in UOA's as higher levels of copper.
Rapid, excessive wear is often not adequately picked-up or even picked-up at all by UOA because the particles generated are too large to be "seen" by spectrography.
The tool was never designed for, and lacks the resolution, to allow a user to determine which oil is "better" than another based on ppm variances in metals as observed in this manner.
There's a good article on the front page of this site by Doug Hillary, that goes into this:
Used Oil Analysis - Bob is the Oil Guy
