Either M1 is bold face lying, or M1 HM can clean -
From M1 web site FAQ -
I thought Mobil 1 as a full synthetic already provided the protection my high-mileage car needs. Do I really need to switch off Mobil 1 to your High Mileage product for my high-mileage car?
I'm currently using Mobil Clean High Mileage with good results. Why should I change to Mobil 1 High Mileage 10w30, which costs more?
Why are you reintroducing Mobil 1 15W-50? Have there been any changes to the formulation, or is it identical to the previous product?
Is Mobil 1 with SuperSyn Technology a fully synthetic motor oil?
What's the difference between a fully synthetic and a synthetic blend motor oil?
What's the overall benefit of Mobil 1 with SuperSyn Technology?
Mobil 1 High Mileage is designed for high mileage vehicles that have been using conventional oils. It's true that most Mobil 1 vehicles with 75,000+ miles should be in excellent condition and would not require some of the Mobil 1 High Mileage benefits. However, most cars on the road today do not use synthetic oils, so we developed this oil specifically for these cars that would benefit from switching off conventional oil.
Back to top
If your vehicle has been maintained well, Mobil Clean High Mileage represents an excellent choice. However, if you believe your engine may have sludge through less-than-adequate maintenance practices, Mobil 1 High Mileage may be the more suitable selection. Mobil 1 High Mileage helps reduce the sludge that other oils can leave behind which can result in extended engine life. For severe cases where sludge and other heavy deposits are present, shorter oil change intervals of 3,000 miles are recommended as clean-up proceeds.
