diesel engines don't run at any specific air fuel ratio so the lean, rich doesn't apply like it does with gasoline engine technologyThe system is adding fuel so it doesn't go lean and burn a piston or that the engine is overfueling or not burning off excess fuel.
Yes, modern diesels don't take long for the turbo to catch up and clean things up. So a puff of smoke isn't going to last long. Kind of a bummer they have all these emission controls now. Diesels quit blowing smoke 30 years ago.diesel engines don't run at any specific air fuel ratio so the lean, rich doesn't apply like it does with gasoline engine technology
basically, black smoke is more fuel than air at a given time than can be burned cleanly .. which is different than incomplete combustion which generally is indicated by white smoke from a diesel.
Incomplete combustion might occur on a cold start where not all the cylinders are working up to speed, and you get this unburned fuel and white smoke out the stacks. Black smoke can just be from a plugged air cleaner or over fueling.. over fueling being the more common. someone mentioned lugging, which is basically overloaded operation and over fueling at low engine speeds.
if the smoking problem is on a modern diesel with emission controls, the black smoke problem is caused by TAMPERING and fools with a heavy foot.View attachment 178956View attachment 178957View attachment 178958
nowadays they have that smoke catcher on them otherwise known as a Diesel Particulate Filter ( DPF),,, but what with electronic controls and HPCR injection they really dont smoke until something is either wrong with them or somebody messed with them.Yes, modern diesels don't take long for the turbo to catch up and clean things up. So a puff of smoke isn't going to last long. Kind of a bummer they have all these emission controls now. Diesels quit blowing smoke 30 years ago.
Pretty much that's what I was sayingnowadays they have that smoke catcher on them otherwise known as a Diesel Particulate Filter ( DPF),,, but what with electronic controls and HPCR injection they really dont smoke until something is either wrong with them or somebody messed with them.
after about 1980 even when they were mechanically injected in stock form they had smoke controls.... 2 stroke Detroit's had the throttle delay built into the rack, and Cummins used the AFC ( Air Fuel Control) to prevent overfueling until they had good manifold pressure... others did the same thing but I'm not familiar enough with those to say what exactly... kinda like most of the old stuff had a smoke limiting device built in, just because there is a requirement not to bellow black smoke..Pretty much that's what I was saying
This is a great explanation (and love the pics!)diesel engines don't run at any specific air fuel ratio so the lean, rich doesn't apply like it does with gasoline engine technology
I've asked this question several times in various forums, and I've never gotten an answer. When a diesel is lightly loaded for a while and suddenly it receives a large load, where does all the black smoke come from? It's my understanding that it's just buildup inside the exhaust and the extra flow of air is just blowing it out, so it's not really from the engine itself.
yes... old diesels without aftertreatment or computers are prone to these problems, far more than the current stuff with exhaust aftertreatment... modern engine with aftertreatment will actually run the intake grid heater during warmup and also run the engine at varying idle speeds to keep the aftertreatment system warm enough to function..Between the top of the piston and that space "quench area" down to the first piston ring, on a diesel it is very wide. If a diesel is too cold or receive too light of load, liquid fuel can begin to puddle in that area. Also the entire exhaust is too cool and the carbon will adhere to all of the surfaces.
The other thing is if the entire cylinder temperature is too cold then complete combustion will not be occuring during the throttle up. So you will get lots of smoke until the temps rise.
Diesels are ALWAYS lean...when they get closer to stoichiomnetric they can burn things.The system is adding fuel so it doesn't go lean and burn a piston or that the engine is overfueling or not burning off excess fuel.
This has happened on properly tuned, efficiently running diesels long before there was anything to regen.Could be a bad regen cycle.
That's my take too. That soot is coming out but at low speed, falls out of suspension, and just builds up in the nooks and crannies. Give it the beans, blow lots of air through the system at high speed, and you just see "lots" of soot--but it's really all the soot that wasn't coming out before. It didn't make any more than when you are on it all the time, it's just an accumulation over time.
