Your engine will be fine. 5-6k miles (8 - 9,000km) is usually no problem for these modern conventionals. With a lot of highway miles (easier on oil/mile driven) in that oil change, one can run much farther than that without issue. You may have pushed the oil a little but modern conventional 5w30 (Group II+) motor oils are much better than those we were using 15 years ago. They use almost synthetic quality base oils.
The Castrol GTX you are using is a good oil, this UOA was 5,049 miles and the TBN was 4.1, which means the oil had lots of life left in it.
Changing oil at 5,000km (3k miles) is a waste with modern conventionals, they go much further than that easily. Run 8,000km (5k miles), and if it mostly highway you can go further.
