Not much I can say about this, other than the fluid came out pretty and still reddish pink in color. Not sure about wear numbers, but glan I have changed it. (not started whne to change in owner's manual). I have only done gas engine UOAs in the past.
Was pretty easy to change once you find a fill hole and buy a very long funnel.
5.7 quarts came out and added the same amount back. I used Valvoline blue bottle D6 fluid.
Keep in mind that this is not an average Joe transmission, it does not heat up that much. Some more info here:
The GM “Voltec” 4ET50 Multi-Mode Electric Transaxle
The Chevrolet Volt is an electric vehicle (EV) that operates exclusively on battery power as long as useful energy is available in the battery pack under normal conditions. After the battery is depleted of available energy, extended-range (ER) driving uses fuel energy in an internal combustion engin
www.sae.org
