Desert monsoon rain
Apple Valley, California
Got our yearly rain this morning 😁. Monsoon rains can show up with no prediction. Never know where it will hit.
We got about 3 minutes of heavy rain which is just enough to bring the humidity up for this afternoons 100+ temps.
Desert dirt is almost waxy, doesn't let water in or out. While I too hope some makes it down Chris' well he'll need more than this.
  • Like
Reactions: D60
"The North American Monsoon, often called the Southwest Monsoon, is a seasonal wind shift that brings increased moisture and thunderstorms to the southwestern United States and northwestern Mexico from approximately mid-June through September.
This change in atmospheric circulation provides critical rainfall to an otherwise arid region
How's your well doing? This should help.
Well is currantly producing water. I can't measure the depth with the pump installed which is a bummer.
My well is in an aquifer that is filled by the flowing Mojave river after a heavy rain or snow melt. It takes 2 weeks from the first flow till the water reaches my well which then comes up 1 inch per day.
This sprinkle is not enough to raise the level any.
There should be a plug on the well seal (about 1/2-3/4") that you can remove to measure water level.
The weather in SoCal caused several outages today from lightning strikes.
Huh? I don't think they did that 60 years ago when they drilled the well. The pump is on the bottom and every 50 ft or so is a torque arrester that expands to keep the drop pipe from allowing the pump to flop around when it starts. There is no way to get anything past that torque arrester.
Gotcha. Haven’t seen those in years. My family owned a water pump company in the Central Valley up until 98 when it was sold. I’ve probably pulled over a thousand submersible pumps & have only seen a handful of those.
Here’s what I was referring to:
https://flojak.com/cdn/shop/files/PSWS4X1_cd2a9606-c5e8-4150-8c16-28d5aaf4e746.jpg?v=1721070084
Mines an 8 inch steel pipe sticking out of the dirt with a homemade metal cap on top. Those toque arresters are on every well around here.
I remember experiencing my first monsoon season in Mesa, Arizona.
I remember watching this wall of sand approaching from the west, the spectacular lightning, and then the heavy downpour of rain as it passed over. The crackle of the lightning and the way it streaked across the sky was surreal.
We got one yesterday, too. Been sooooo dry here. The problem of course is the lightning that can set our tinder forest ablaze, so you pray it actually drops water when the clouds roll in. I don't think Chris has much vegetation around him -- just a hot garage, a hot neighbor girl and snakes crawling all over the house.
