[Cut Open] Pro-Tec 166
Texas
This filter was on the Monte Carlo for a little over 8 months and exactly 3,967 miles. Nothing too exciting to report, seemed to hold up nicely for a budget filter. The ADBV, although Nitrile, held up very well. I've had the filter sitting off the car upside since the oil was changed about 3 weeks ago, when I cracked the shell, oil still poured out and as you can see, the valve is still very pliable. Not bad for a closeout filter from Rock Auto.
Nice c&p. Filter did well. Thank You
Originally Posted By: SOHCman
not bad, cellulose? ultra like metal end caps.
Cellulose is correct. These are Wix made filters, seem to be very similar, if not the same as NAPA ProSelect filters.
Wix Pro-Tec information (limited) can be found here.
