This engine was in a Dodge shop truck. Another truck ran into it and totaled it. Insdeat of trying to fix it I decided to use the engine for a re-power project.
[img=http://thumb4.webshots.net/t/63/63/8/4/61/2752804610096396344HbjQrr_th.jpg]
The gear housing had a crack around one of the front cover mounting bolts from the wreck that I need to fix. While I had the tig warmed up, I filled in the bore for the killer dowl pin.
[img=http://thumb4.webshots.net/t/61/61/0/90/42/2905090420096396344nKomab_th.jpg]
This doesn't show much other than how clean everything is after 126K miles. Even the top end is this clean, the rockers are just as spotless as the crank is. I'll get a pic of the rockers when I do the tune up.
[img=http://thumb4.webshots.net/t/12/13/3/38/71/2586338710096396344InkDtY_th.jpg]
The cam looks exceptionally well considering it is a flat follower cam, as is the 6CTA Cummins. This pic shows what appears to be some fretting on one of the lobs, I when back and inspected that lobe and it looks fine. Must be the flash and oil film not getting along?
