I just had my coolant drained and filled twice but something strange happened and I want to know what everyone thinks.
Firstly, it's a Ford on a 5 year / 100k interval.
I forgot the 5 year bit, and so the car had the first drain and fill done at 8 years / 70k.
Prior to it being done, the color in the reservoir was good, and there were no cooling issues. The heater blows hot very quickly. This has not changed.
For the first drain and fill, I gave 2 x gallon jugs of G-05 and distilled water to the shop. From what I got back and how it was explained to me, I can't tell exactly how much of each was used, nor could the manager, so we agreed to do it again. But my concern was based on the fact that they seem to have used a lot of coolant and not enough distilled water.
So 2 weeks later, they did it again, this time keeping track of the quantities. Out of a 10.6 quart capacity, they drained as much as they could and then filled up 6.5 quarts of 50/50 mix to get to the full line in the reservoir.
The strange thing that happened though is that when I was shown the bucket with the drained coolant, it came out a brown color. Not thick, just brown. This was strange because I saw some of it coming out (steaming) during the drain process, and it looked quite clear and thin at the time.
Any thoughts on what is going on? Everything else is mechanically absolutely fine. No oil leaks. The coolant has always looked nice and clear in the reservoir, before, during and after all this work.
Apart from the possibility that there was (and maybe still is) some gunk in the system / radiator and the second hot drain got it out, all I can think is that the bucket was already dirty.
If the system was dirty, why didn't I see it in the reservoir during the intervening 2 weeks?
