So now that I have a computer and keyboard to type on instead of a phone here is the dilema. To do this engine properly, it will need bored to .010 over and I need to find a crankshaft that is within spec, and then find a rod to match to it. That will take some time.
To use the engine as is, it would be best for me re-use this rod, as the exisiting rod and crank is already shot. There is no machining on it, its already worn close to if not at .010 over spec and if you turn it to .020 the hardness will be gone.
So based on the scoring present, if I polish the crank with crocus cloth, and polish the rod, will the pounding just be a noise issue or will it just snap? If just noise / knock, I dont care.
