Can someone provide the timeline of what has happened with the reduction of ZDDP in modern automotive oils? When did they start restricting it? What API rating i.e. "SG SJ SL SM SN" did they first start reducing it? How much ZDDP is in the common motor oil you might see on the shelf at Walmart or the parts store these days. What year did the changes take place?
It just seems to me that say, back in 1995 you could walk into a parts store and grab a common bottle of 10w30 and it would be suitable to use in an antique Model T, a vintage 1969 Camaro, your Briggs lawnmower engine, or put in the Mustang 5.0 you might have been using as a daily driver.
Nowadays there's ALL SORTS of specific oils for new cars, old cars, lawnmowers and what not and if you don't use the exact one for your application, then something is likely to be damaged. Can someone help explain?
