Compression that high?
Originally Posted By: asand1
Bottom line is this engine has a compression release, and you don't have more compression than you did, especially at starting rpm.
http://tinypic.com/player.php?v=6draeo%3E&s=8
http://tinypic.com/player.php?v=2wf7inb%3E&s=8
just for you my friend
Originally Posted By: meep
I think the very nature of this forum, is that if you put it out there asking the question, people are going to respond. that's why we post. what else did you want? (that's rhetorical.)
that's fair. my curiosities were more inline with 'is this common/normal' was all
from that video I think it's "normal". A small mower that can be lifted briefly on compression stroke. Not strange, put your feet on the deck so that you don't start it and then drop it on your feet... brrrr.
Ok, it is not normal, and I am 99 % sure that you do not have the full compression relief you should have. I am afraid to cure the problem you will have to remove the head, and the valve cover door to access the valves. Clean carbon, and check tappet clearances. If there is to much clearance you will have to much compression. Or just remove valve door and check clearances first.
