OK. I remember my mechanic saying that my Buick 3800 S2 has a cam sensor. So my Buick probably rotates twice before firing up. It does rapidly get oil pressure after starting engine.
I also remember my mechanic saying that my Jeep 4L rotates 3 times before firing up. I could hear it cranking over longer and then suddenly vroom it'd start.
The sound of the Honda 2.4L cranking, then starting leads me to suspect it rotates 2-3 times before firing up. Plus it gets oil pressure fast.
The Hyundai 1.8L seems to start immediately, but then takes longer than expected to reach full oil pressure. After cold start the engine rattles for 5 seconds sounding like after an oil change with a new filter that wasn't prefilled.
yes the rattling is the chain tensioner not being filled with oil. My 1.5 doesn't do that.
If there's no cam sensor, or it's faulty, it's still possible (if programmed to do so) to start a GDI but the ecu needs to take a guess which piston just passed TDC, and if wrong take the opposite piston. You'd need 3 revs for that.
