Originally Posted By: Turk
^ LOL!!
The reduced oil burning stayed linear throughout the run of PYB 5w30.
I switched over to Castrol Edge Gold Bottle, as I am more of a user of high quality Synthetics, even though PYB is top shelf Dino. Plus, I have to start using my MASSIVE stash of Edge, M1 AFE & M1 EP from the Autozone $1 a Quart haul!
Needless to say, the 15,000 mile Edge will stay in for a much longer TBD mileage run. No plans on running another "Kreen clean" unless it creeps back up later.
The PCV has been changed 4,000 miles ago and was in before & after it was burning a lot of oil, + I cleaned it out with Carb/Injector Cleaner recently, being the OCD person I am...
My kind of guy.
lol
I gotta run a top-end cleaner through this new to me Fit. 160k miles nearly and I'm sure the PO (a lady no offense) I doubt ever had the throttle body cleaned.
Usually, I'll buy a can of Power Foam from Amsoil and do a combustion chamber soak on top of the pistons and during ingestion it's cleaning the intake anyway. Plus, EGR gets some love and I can use some of the cleaner to wipe down the throttle plate itself while I let it soak.
I only do those types of top-end cleaners literally just before I change the oil so I get to see how much carbon gets loosened into the drained oil. Some idle oil flushes I've had similar results for carbon removal; compared to a drain of oil without any sort of cleaner added.
Also, I meant to say a crankcase additive like Kreen in my previous post. Not sure what an in-tank cleaner would do for coked oil rings.
