Is there any kind of clear hose or inline sight glass arrangement that I could put inline up and downstream of the filter (Frantz or M-G) to allow some kind of visual check on the filtration? Thanks, it's a great forum.
Wouldn't areturn line from a Frantz be close to zero pressure?quote:
Originally posted by Bill Plock:
I looked into sight glasses a few years ago for diesel fuel system problem. I ended up using a glass inline fuel filter from autozone that had 1/4 npt fittings on each end. I removed the filter element and it worked for my application but it was low pressure/vacuum... Not sure it would work for a pressurized oil line..
Good point.. The in-line glass fuel filter with the element removed may work... Also, thinking back, the fitings on the unit I bought from Autozone were 1/8 NPT (not 1/4 NPT as stated in my previous post)quote:
Originally posted by XS650:
Wouldn't the return line from a Frantz be close to zero pressure?
Oh, I'm sure that it would show no more then the dip stick for clarity ...and a hand feeling the warm canister would tell if the thing is working.quote:
I'm just not understanding the purpose of something like this.
Leased vehicles, extended warranties, lots of quick lube places, and also cars are much more reliable and safe than they used to. The newer, more accurately machined engines have tighter tolerances and consume less oil. You'd tend to conclude then that people check their fluids less often. This is America man! Well, at least where I come from. It's trendy to toss out for something new and shiney even though what is replaced requires a little work to keep in shape.quote:
Originally posted by TP4ME:
"For some reason this forum has the smartest people." Well, I'm not one of them, but let me guess: it takes a certain conceptual ability (aka: imagination) to understand the process of wear, particulates and the potential benefits of bypass filters. Most folks no longer have that ability, thanks to...?
Yeah, whoever installs a sight glass will have a running, mobile showcase!quote:
Which may be the reason for devices such as the Frantz salesmans setup I saw on eBay a while back which would pump dirty oil through the TP filter and into a glass jar for the skeptical to see!
