Coincidentally, the oil changes for my '86 Ford 6.9L diesel pickup and our '00 Honda Accord V6 came near to each other. I dump my used oil into five gallon containers for recycling and then clean up the drain pan with a little brakecleen and rags. The HDEO (in this case Shell Rotella 10w30) is always a bear to get cleaned out of the pan, even with the help of the brake cleaner. The solvent doesn't "cut" the oil very well or very quickly, and the oil will really stick to the pan when I upend it for draining.
On the other hand, the 5w30 Castrol GTX/Syntec home blend cleans out rather easily with the brake clean and doesn't stick as well when the pan is upended.
Both oils have about the same mileage, 6-7000 miles, and the ambient temp was roughly the same. If anything, it was a little colder for the Castrol.
Anyway, I'm wasting my time wondering if the differences say more about the difference between a HDEO and a PCMO or the differences between Shell Rotella and Castrol. I've had good luck/OAs long term with both oils in their respective applications.
