Not quite home repair, but I figure church is close enough.
There's a large kitchen in the basement, which was expanded some years ago. (The church was built in 1968, and I estimate the kitchen was expanded in the '80s or '90s.)
As part of the expansion, a couple of sinks drain into a dedicated sump pit rather than directly into the sewer system. An electric sump pump then pumps the grey water up and over and down into the sewer.
Anyway, unlike a conventional sump pit for ground water from the weeping tiles, this one collects dishwater debris and grease.
It had been smelling really foul for a few years, so yesterday another fellow and I tried to clean it out.
We bypassed the lost to run the level down as low as possible, added much bleach, and sprayed off as much of the coagulated fatty buildup as we could, using a pressure washer.
When that quit doing much, we resorted to stiff brushes and bleach.
We ran the sinks to add clean water and did several rinse cycles, and finished up by adding a chemical that's supposed to eat the build-up and get rid of the odor.
I'm told that as of today the basement smells much better. I hope it lasts.
