Originally Posted By: TooManyWheels
I have that truck in a '97 with the 5.7. Plus one to the comments on alternators and transmissions, and intake gaskets/Dexcool.
Unless you have the 140 amp alternator, the bearings go bad every 50-60K. My long time experience with GM is that the belt driven acessories usually start to fail around 100K, plus or minus, so you may already be on the second round for the water pump, ps pump and AC compressor. If you need a new compressor, get one of the redesigned alternatives with a one piece case, so it won't leak at the joint like the factory one.
Be wary of the transmission and put money aside for reparing it. Mine went at 75K, despite decent maintenance. The planetary gears (hard parts) are known problems.
Window motors fail, but aren't TOO bad to replace. I've needed to replace the lower ball joints, but that may be due to wheels with increased offset. Tie rod ends too, but I consider that normal maintenance.
My truck has certainly been around the block, but my experience (and those of friends with similar trucks) is sure different than yours. It's amazing how experiences vary among owners.
- My original transmission lasted 200,000 miles
- Original water pump 180,000 miles
- Tie rod ends are original at 367,000 miles, as are all steering/suspension bushings and components
- AC Compressor fine with 367,000 miles
- Original power steering pump with 367,000 miles
