Why do you have to have the engine running to check the transmission fluid level? The transmission has a pan like the engine, so I was wondering why the vehicle has to be running to check the trans fluid, but not for engine oil? thanks
For most cars with an automatic transmission, the torque converter holds quite a bit of fluid and it's fluid level is "above" the level of the sump, so it needs checking while engine is running and fluid is being pumped around the transmission system. The fluid is being sucked out of the sump and ciculated through the Torque converter, the valving, and through the cooling system. At engine off, the fluid from the Torque Converter drains back into the sump and runs high up on the stick.quote:
Because of one BIG variable - as in "how long" after shutdown. By specifying that a fluid level check be done at operating temperature with motor running, the results will be more consistent for comparisons. As Mike stated above, fluid expansion volume at operating temperature will also elliminate the level variability that would result form a cold check at, say 50 degrees F. compared to another done at, say 95 degrees F. Some car makers provide dual calibrations on their ATF dipstics for both cold and hot readings, but they inevitably recommend that doing the check when at operating temperature is more accurate. At least be glad you can check the ATF level on your car's trannie. Some GM transmissions (others, too?) have neither a dipstick nor any convenient means to top-up or refill.quote:
Originally posted by SR77:
...I don't know why the manufacturers could not just figure out how much transmission fluid should be in the sump after ther TC drained to make it easier...
I always checked my Honda Accord AT with engine running, PRD21, on level ground, 25 mile drive and it was a the full mark. After I shut off the engine, it go 1/4in higher than full mark. If I put on full mark on it with out the eninge running, it got on low mark with the engine running! So confused!quote:
Originally posted by Ray H:
Hondas, at least in prior generation automatics, specified checking ATF level with the engine off. Everyone else, so far as I'm aware, specifies checking with the engine running. As I understand it, the reason for rowing through the various gear ranges is to bring fluid into all areas of the valve body and the transmission. The dipstick is calibrated to read accurately only in this condition.
I'd be happy to take that crappy Honda off your hands for a reasonable price, of coursequote:
Originally posted by farang:
Honda sucks as I learn more in this board:
Specific PS fluid. A lot people did not know!
SOHC
Belt type timing belt.
Interference type (if belt broke, you say bye bye)
Stupid way to check ATF.
Plastic windows rail (or whatever it called).
"Hic kup" trans type.
Never buy a Honda again!
