Originally Posted by burla
Originally Posted by y_p_w
Speaking about recommendations and certifications, I got curious about a particular car I'm thinking of getting, so I downloaded the 2018 Honda Civic Si owners manual. It's kind of an eye opener. The first thing they recommend is Honda Genuine Motor Oil (no specific weight given outside of a chart), then a 0W-20 detergent oil with the API certification (really the ILSAC starburst) seal. There is no specific letter standard (i.e. API SN) mentioned anywhere in the owners manual.
Quote
https://owners.honda.com/vehicles/information/2018/Civic-Si-Sedan/manuals
Recommended Engine Oil
• Honda Genuine Motor Oil
• Premium-grade 0W-20 detergent oil with an API Certification Seal on the
container
This seal indicates the oil is energy conserving and
that it meets the American Petroleum Institute's
latest requirements.
Use Honda Genuine Motor Oil or another
commercial engine oil of suitable viscosity for the
ambient temperature as shown.
You may also use synthetic motor oil if it is labeled
with the API Certification Seal and is of the
specified viscosity grade.
I'm not sure if maybe there's something on the oil cap that says anything more specific. I suppose it's always possible that someone finds or is given an older 0W-20 - maybe even as far back as API SJ.
This From Your Gov't....
The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket or recycled part. The manufacturer or dealer can, however, require consumers to use select parts if those parts are provided to consumers free of charge under the warranty. They can only require you to use Honda oil if they provide it for FREE, or they will loose in court. As that is a monopoly which goes against American principals. Go figure a car maker from a communist country would see it different, don't be afraid to deliver them some American justice if they mess with you.
The act is outdated so much so that Ashland and others are petitioning government to update language to include oils spec. The BIG3 are against this as they claim failure of unapproved oils cause damage in newer technologies needed to meet fuel efficiency requirements. If you keep records on oil changes dealers want receipt and if oil is not on list then it is unapproved and manual states that could void warranty. With long finance plans warranty is longer and the disabled such as myself will pay for 7 year warranty anyhow note is not as long. What gets me is one company will only certify conventional not synthetic but another will certify synthetic so that makes it tough on consumers. Oil companies try to combat this by having their own warranty but you are to use their product exclusively.
