Originally Posted By: danielLD
ahhh, I wish people had to post their job title and field in their signatures. I challenge the OP to actually get a half way decent UOA.
It's a new engine. One thing many here (who ARE NOT UOA analysts) miss, is in a brand new engine, FD won't cause much wear. Just wait till later on when ferritic micro corrosion becomes present.
Oil_film_movies. A magnetic drain plug won't do diddly in a modern engine, yes it's fuel dilution causing that filter to load.
To me, it seems you are conflicting with yourself. Unless I am misunderstanding your post.
Your going on about people who are not UOA analysts and FD wont cause much wear etc. Yet the UOA does not show FD.
So which is it?
For me, I assume fuel, even though the UOA does NOT show it, because EVERY Skyactive engine seems to shows fuel since it was produced starting around 2012. No big deal, direct injection engine like others and has been rock solid.
No contradictions here. You don't understanding the testing methods which is ok, but it's why you and most people are confused and should listen.
It should be well known by now that Blackstone says 0.0% fuel when often times it's as high as 5% before they detect. Many of my little side project UOA's (race cars) were having Blackstone say 1.5% when GC revealed 8-10%. Flashpoint is not an accurate way to read fuel dilution.
Many more issues with that UOA from a testing stand point. Water is another one that is definitely not at 0.0.
Fuel Dilution is one thing most people here don't know how to solve. So people accept it as normal, even though it's not. Address the ring seal and your fuel economy and power will rise. Leave FD uncontrolled, it creates micro corrosion, wear, and a lot of other bad things. Most here just say "oh, FD is ok, nothing wrong", yet that is the number one cause of engine wear or any wear for that matter.
Track time and prolonged redline creates little to no wear. FD is what destroys engines.
One study I did with Subaru, showed when we controlled the FD in the tracked STI's, wear almost instantly disappeared even though these cars were hitting redline for prolonged hours. We then started pushing the cars even harder. There's more to FD, but you can get an idea.
Don't leave us in suspense. Without giving away the store, how does a civilian "control" fuel dilution in a modern DI engine and preserve the warranty at the same time? I'd love to have a strategy.
So which is it?
