Originally Posted By: rollinpete
Originally Posted By: incognito_2u
So, As you can see, The 1999 Corolla that's in my sig is a car that's notorious for burning Oil......a product of not enough drain holes or too small a drain hole by the Piston oil control ring groove that eventually gets "clogged" and creates an "oil Burning" condition. Now the car in question was purchased 10 months ago, used, from a little old lady (literally) who had the car serviced by a reputable Service center in the area that has a great reputation of doing quality Work for a fair price.....upon looking at the service records of the vehicle (specifically the Oil Change records), the Oil used was Bulk dino Pennzoil 5W30 with a Pennzoil Oil filter, approximately every 5000miles/6 months. What I have done to
possibly prevent this from being an issue was to give it an initial "Kreen" piston soak and to change the Oil to 5W30 Pennzoil Ultra Platinum with an Fram Ultra Filter.
I truly believe that the steps I took to cure/prevent the oil burning issue have worked!!
So far, 4 thousand miles on the car since purchase and it hasn't burned a drop of oil......
Whats your kreen piston soak? Thanks...
Remove spark plugs, add 3 ounces of “Kreen” through spark plug holes, rotate engine one full turn and repeat.
Let sit overnight, then turn over engine with spark plugs still removed. ( Clears out residual fluid)
Put plugs back in, start engine and let the smoke show begin.
Run car for 20 minutes, stop car, change oil / filter and your good to go.
