Vehicle: '98 Ford Ranger 2.5l
Coolant: Prestone Extended Life (aka "New Prestone / AF2000")
Flush: Zerex Super Radiator Flush
Okay, here's my problem: I premixed coolant/water (50/50) to 6.8l as per owner's manual, but I could only get ~5.3l back into the system. This was two days ago and I've managed to add another ~.5l since. While draining coolant, the truck was on level surface, but I didn't open the block drain(s). Now I took my time with this and let the radiator drain thoroughly, I allowed the thermostat to open several times during the flushing and rinsing process, and I am sure my coolant mix was measured correctly. Yes, I allowed engine to run with radiator cap off until air and coolant gurgled out; also squeezed upper hose to get more air out, had heater on full-blast during the entire process, and drained & filled the overflow resevoir. My question is, could that much water (~1.5l - 1.0l) still have been in the block and not drained out? I fear my 50/50 mix is now something like 40/60 (w/c)...and my hydrometer shows new mix to only be good to -22F. What did I miss?
Thanks...
C.T.
[ November 03, 2005, 01:50 PM: Message edited by: Crack_Tan ]
Thanks...
C.T.
