Say you have 2 cars that always fail on the same item within 30k (gasket, O2 sensors, radiators, exhaust manifold, AC, etc) and one of them had a bad coil not so long ago (210k miles). You end up buying an OEM because you don't know if you have time to mess around and buy one on the Internet.
Now let's say your other car already has 180k miles with this coil and it is having a bit more miss fire than you remember from the past, and even with a platinum plug it still doesn't run as smooth as before. Do you go ahead and change the coil as a preventive maintenance, and keep the old one as a spare?
