Originally Posted By: AZjeff
Originally Posted By: motor_oil_madman
I do believe a 7" disc is going to naturally spin slower
because it has to travel farther to make one rotation compared to the smaller wheel.
You would believe wrong. If your grinder spins @ 10,000 rpm it spins at 10,000 rpm. It may take longer to spin up with a bigger wheel but not much. A 4.5" wheel has a diameter of 13", a 7" wheel is 22" diameter. You get 70% more cutting surface per revolution and it's traveling 70% faster but it's going to bog down, think of being in 5th gear when you should be in 2nd.
If you do this make sure the disc isn't overlapping the grip area.
I read this at BITOG! Epic fail. Think of pulleys
